| Relay number https://slantsix.org/forum/viewtopic.php?t=39865 |
| Author: | Rick Covalt [ Sat Apr 17, 2010 5:42 am ] |
| Post subject: | Relay number |
If I want to put a relay on an electric fan as recommened.What is the part number I am looking for? It seems people just grab them at the yard and use them off about anything. Sorry, I'm not that bright electrically. I searched some but didn't find a part number other than Dan's delayed timer one. I'm headed to Advance or NAPA in the next hour. Will either of these places have a suitable relay? Rick |
| Author: | walpolla [ Sat Apr 17, 2010 6:49 am ] |
have a look at this catalogue ,you can pick which type you want from there. I do'nt know if Narva is sold in the US,but it should help you. regards,Rod |
| Author: | Rick Covalt [ Sat Apr 17, 2010 7:13 am ] |
| Post subject: | Dorman |
Picked up a Dorman 84601 at Advance. Thanks, Rick |
| Author: | carlherrnstein [ Sat Apr 17, 2010 12:21 pm ] |
Watch out for dorman realys, the one i picked up from autozone didn't work............. keep an eye on the temp gauge!!!!!!!! |
| Author: | coconuteater64 [ Sat Apr 17, 2010 3:10 pm ] |
Quote: Watch out for dorman realys, the one i picked up from autozone didn't work............. keep an eye on the temp gauge!!!!!!!!
Watch out for autozone. Period.
| Author: | carlherrnstein [ Sat Apr 17, 2010 7:23 pm ] |
Quote: Quote: Watch out for dorman realys, the one i picked up from autozone didn't work............. keep an eye on the temp gauge!!!!!!!!
Watch out for autozone. Period. |
| Author: | 64DartVertible [ Tue Apr 27, 2010 3:31 pm ] |
Tyco (formerly Bosch) is the only brand of relays I use. They're still as good as when they had the Bosch name. You can get them off eBay pretty cheap, too. |
| Author: | Rick Covalt [ Wed Jun 02, 2010 3:02 pm ] |
| Post subject: | Dorman Crapped out |
As some had mentioned the Dorman relay shorted out at Mason Dixon at the races.It was only in use for a couple weeks. Probably for a couple hundred miles tops! Charlie had a Bosch(I Think) relay which was twice as heavy as the crappy Dorman I bought. Live and learn. Is there a Tyco Part # for the 5 pin relay I can look for? Found them on E-bay: 12VDC 30 amp 5 pin Tyco relays. Part number V23234-A1001-X036. |
