It is currently Wed Jun 17, 2026 1:00 am
 Post subject: harmonic balancer
PostPosted: Wed Apr 21, 2010 4:34 pm
hi the seal broke on my harmonic balancer can it be fxed
PostPosted: Wed Apr 21, 2010 5:01 pm
Is the front timing chain cover seal leaking at the balancer or did the rubber isolation ring come apart?
There are shops that will rebuild your harmonic balancer but usually people just replace it with a good used one.
http://www.dalemfg.com/harmonicbalancer_018.htm
PostPosted: Wed Apr 21, 2010 5:03 pm
It takes special equipment to rebuild a harmonic damper. Ever make molds and vulcanize rubber?
Also, descriptive subject lines help attract attention to your posts. By the transitive property of message boards you help yourself by providing descriptive subject lines. Help us help you help yourself.
 Post subject: reply harmonic balancer
PostPosted: Wed Apr 21, 2010 5:04 pm
the seal just broke off split in two
PostPosted: Wed Apr 21, 2010 5:07 pm
i think it would be easyier to just by one then try to fix it i thought there would of been a way to fix the seal
PostPosted: Wed Apr 21, 2010 7:22 pm
The damper has a metal ring held to the metal hub with vulcanized rubber. What are you referring to as the seal?
