| dorman/HELP valve cover grommets https://slantsix.org/forum/viewtopic.php?t=39928 |
| Author: | carlherrnstein [ Wed Apr 21, 2010 6:50 pm ] |
| Post subject: | dorman/HELP valve cover grommets |
Dorman/HELP valve cover grommets part numbers for a 1985 slant 6 (other years may apply) Breather grommet part number is 42344. It's labeled as a pcv grommet but it works,it has (6042344 M CHINA) molded in it as big as can be. PCV valve grommet part number is 42065. It has (65 taiwan) molded in it. I started this thread because i kinda had to search for the numbers and it wasn't super clear. I hope this helps anyone with cracked hard grommets. P.S. can someone follow up with part numbers for the early type valve cover grommets (the ones with only two holes) |
| Author: | SlantSixDan [ Thu Apr 22, 2010 1:08 pm ] |
Early type cover '66 to '69 uses only one grommet, same PCV valve grommet as you list here for '70-up cover. '60-'65 covers do not use grommets. |
| Author: | Mark Mallett [ Thu Apr 22, 2010 2:12 pm ] |
This is a very timely post - I was cleaning my old grommets today in the laundry tub and voila! - I washed the pcv valve grommet straight down the drain - after the initial scream I started to laugh hysterically - damn funny $#!+! Danke for the part #'s - I see a trip to Can Tire in my future Peace |
| Author: | carlherrnstein [ Thu Apr 22, 2010 2:23 pm ] |
Thanks Dan I knew they were different somehow,glad to see this is helping. |
