| Source for exhaust hangers, carb linkage clips https://slantsix.org/forum/viewtopic.php?t=39929 |
| Author: | phogroian [ Wed Apr 21, 2010 7:15 pm ] |
| Post subject: | Source for exhaust hangers, carb linkage clips |
I need exhaust hanger brackets for a '75 Dart, and would like a few sets of kickdown/throttle/choke thermostat linkage clips. What is the best source? |
| Author: | KBB_of_TMC [ Thu Apr 22, 2010 10:16 am ] |
I just saw that the local Advance "Help" section had packs of such things - probably there are better sources, but less convenient. |
| Author: | SlantSixDan [ Thu Apr 22, 2010 1:26 pm ] |
Use new style exhaust hangers (round rod tack welded to pipe or muffler, rubber bushing bracket at floor pan). Dorman and Echlin sell multi-packs of the clips. |
| Author: | Charrlie_S [ Fri Apr 23, 2010 5:18 am ] |
Quote: Dorman and Echlin sell multi-packs of the clips. |
| Author: | SlantSixDan [ Fri Apr 23, 2010 9:06 am ] |
Quote: Those clip packs do not have the small clips for the choke rod.
The ones I've bought always have — and I wind up with a bunch of other-size clips I can't use. You can get the correct clip individually, too; Dorman # 118-005 or 118-025 depending on whether you need the RH or LH variety for the 1920/BBS/W or for the 1945/6145 (don't have which is which in front of me).
| Author: | phogroian [ Fri Apr 23, 2010 9:29 am ] |
Thanks! |
| Author: | Charrlie_S [ Sat Apr 24, 2010 4:05 am ] |
Quote: Quote: Those clip packs do not have the small clips for the choke rod.
The ones I've bought always have — and I wind up with a bunch of other-size clips I can't use. You can get the correct clip individually, too; Dorman # 118-005 or 118-025 depending on whether you need the RH or LH variety for the 1920/BBS/W or for the 1945/6145 (don't have which is which in front of me).The correct clip is Chrysler part number 2465560 which is superseded by 4041917 I just went through this about 2 weeks ago. Customer bought a 76 Valiant for his daughter, and I had to replace a missing choke t-stat. |
| Author: | 1969ronnie [ Sat Apr 24, 2010 4:57 am ] |
hi, tom at accurateltd.com has slant 6 exhaust hangers and exhaust systems for slants. they are very helpful. ron |
| Author: | SlantSixDan [ Sat Apr 24, 2010 9:32 am ] |
Quote: The part numbers you list (which are the smallest in the "multi pak", are for a 5/32 inch rod. The slant six choke rod is 1/8 inch. It might be made to work, but will not fit properly.
Okeh. They work for me.Quote: The correct clip is Chrysler part number 2465560 which is superseded by 4041917
That's for the 1945/6145? Or for the others?
