Poly Motor Mount Issue
https://slantsix.org/forum/viewtopic.php?t=39952
Author:  64 Convert [ Fri Apr 23, 2010 2:18 pm ]
Post subject:  Poly Motor Mount Issue
Author:  SlantSixDan [ Fri Apr 23, 2010 2:25 pm ]
The difference was rubber compound, not size/shape. The non-convertible mount fits and works just fine in convertibles. Sounds like something else is the matter with your setup; I'd guess your trans mount is badly sagged and/or you're working with incorrect motor mount brackets.
Author:  64 Convert [ Fri Apr 23, 2010 4:10 pm ]
The transmission mount is old stock US made and has very few miles on it, and all the brackets are original. Everything I've replaced over the years has been Mopar, and looks like original. The engine was never rebuilt and I just swapped a '79 in place of the '64. There is also no visible collision damage anywhere except at the driver's door.
I don't know what the problem is, but the poly mounts are shorter than both the OEM and the aftermarket parts and won't work in my car.
Author:  Doc [ Fri Apr 23, 2010 4:25 pm ]
Did the 64 engine's oil pan & pick-up tube get swapped onto the 79 engine during the swap?
Author:  64 Convert [ Fri Apr 23, 2010 5:19 pm ]
Yes.
Author:  maxracer21 [ Fri Apr 23, 2010 5:41 pm ]
Post subject:  mounts
I also have a 64 vert.................does anyone have a parts number reference to check that a conv. lists the same part number?
best regards max
Author:  SlantSixDan [ Fri Apr 23, 2010 7:43 pm ]
Post subject:  Re: mounts
The convertible doesn't list the same part number. It lists a different part number. Again, the difference is rubber compound, not dimensional. There's something tweaked on the OP's car.
Author:  maxracer21 [ Sat Apr 24, 2010 5:18 am ]
Post subject:  mounts................
long as it works for a pass ..................life will be good
Author:  SlantSixDan [ Sat Apr 24, 2010 9:32 am ]
If for whatever reason your engine is sitting too low, shim the mounts with plywood and call it good.
Author:  maxracer21 [ Sat Apr 24, 2010 12:01 pm ]
Post subject:  plywood mounts
I've raced worse..............after 45 years...........if it just doesn't work out I have access to facilities to do a short run of ones that do...............so convertible people be happy ................we have resources.
take care, life comes at you very quickly
