It is currently Sat May 02, 2026 10:13 pm
 Post subject: od tranny rules!
PostPosted: Sun Aug 04, 2002 10:37 pm
Thanks again doug! Now I have to take you for a ride in it. I love 4th, it's so tall! Finaly good gas milage.
Anyway, check your email. I think it's guiness time.
Richard-c@e-d-a.com
 Post subject: Re: od 4-speed success
PostPosted: Mon Aug 05, 2002 9:01 am
: Thanks again doug! Now I have to take you for a
: ride in it. I love 4th, it's so tall! Finaly
: good gas milage.
: Anyway, check your email. I think it's guiness
: time.
Great job on the conversion, did the up-side-down 3-4 linkage rod give you any clearance trouble?
What did you do about the different driveshaft and speedo cable you needed for this conversion?
(early B&T tranny to the later OD 4-speed)
PostPosted: Mon Aug 05, 2002 2:04 pm
: Great job on the conversion, did the
: up-side-down 3-4 linkage rod give you any
: clearance trouble?
well...... it's at the end of it's thread, and I needed to bend it it the vice, but other than that no. I aalso took the oportunity to replace all my paperclips with the spring loaded clip units that I got at napa.
: What did you do about the different driveshaft
: and speedo cable you needed for this
: conversion?
Well, this guy I know gave me a shaft to use, and i had it shortened by 1.5 inches. It was hard up against the tranny but level with the diff. 1.5 inches was perfect fit.
speedo? what's that? I unclipped the old style gear and crammed the square drive end in the hole. I haven't made it out to the yards yet so I haven't got the real one. So far, after 1000 miles, it hasn't fallen out yet, and no zipties (I got skills!!!!)
can I take you for a ride in it soon? Did you get my email?
: (early B&T tranny to the later OD 4-speed)
: DD
Richard-c@e-d-a.com
