Carb throttle linkage
https://slantsix.org/forum/viewtopic.php?t=39974
Author:  kman [ Sun Apr 25, 2010 1:49 pm ]
Post subject:  Carb throttle linkage
I need to upgrade my throttle setup. its a non cable type. the set up now, will not allow the carburetor to open up very much. very sloppy. Cable Bound?
Do I need to replace the complete setup including the gas peddle?
in the mail is the Super Sweet Radiator made by Randy......Thanx SlantsixDan.
Author:  SlantSixDan [ Sun Apr 25, 2010 5:56 pm ]
Post subject:  Re: Carb throttle linkage
There's no cable to bind in a non-cable type. Perhaps some of your bushings are loose and sloppy (or missing), or maybe the kickdown linkage is screwed up or hitting the exhaust pipe, and blocking full travel. Have you checked?
Pedal assembly, yes.
Author:  Mark Mallett [ Mon Apr 26, 2010 3:24 am ]
Speaking of the kickdown linkage I presume there is some type of retainer for it at the tranny - mine has fallen out and I'm wondering what holds it in - heh.
Author:  kman [ Mon Apr 26, 2010 5:01 pm ]
Post subject:  cable bound?
Cable Bound/ = should I go cable? the kickdown has no restrictions or anything like that. i'm wondering if it is the right carburetor on the darn thing
