| what voltage at the coil? https://slantsix.org/forum/viewtopic.php?t=39988 |
| Author: | dookdart [ Mon Apr 26, 2010 6:48 pm ] |
| Post subject: | what voltage at the coil? |
for this 65 were working on. I'm still playing around with the electrics. I installed the new voltage regulator and horn relay today. some progress. Someone installed a Mopar Perf. electronic ignition, so there are some more wiring bodges to deal with. In my "pre-first start" checklist; I checked the voltage at the ballast resistor with the key in the ON position....it has just shy of 10v. The batter voltage is at 12.1 v. I THOUGHT the ballast resistor would have 12v in the "start' position, then 6 in the run position. Is that correct? But only for points? I assume the ballast resistor was changed for the MP electronic ignition.....so what should the voltage be? 10 or 6? |
| Author: | SlantSixDan [ Mon Apr 26, 2010 9:25 pm ] |
| Post subject: | Re: what voltage at the coil? |
Quote: I THOUGHT the ballast resistor would have 12v in the "start' position, then 6 in the run position. Is that correct?
No. The ballast resistor is bypassed during cranking by a separate wire.Quote: I assume the ballast resistor was changed for the MP electronic ignition.....so what should the voltage be? 10 or 6?
It's a ballast resistor; its output changes depending on load and load profile. Your 10v reading sounds about right.
| Author: | dookdart [ Tue Apr 27, 2010 12:01 pm ] |
yes...no load measurement. I just stinks working on other peoples mods. Thanks for the help Dan!!! |
