gage or sender unit?
https://slantsix.org/forum/viewtopic.php?t=40004
Author:  dookdart [ Tue Apr 27, 2010 6:14 pm ]
Post subject:  gage or sender unit?
What is the best / easiest way to tell whether the gas gauge is kaput - or the sending unit is at fault?
car is a 65. gas gauge pegged at E, all other gauges work properly.
Author:  SlantSixDan [ Tue Apr 27, 2010 6:36 pm ]
Pull the wire off the sender and briefly ground it (a second or two) with the ignition switch "on", while a helper watches the fuel gauge. If it moves at all, then the problem is likely either a bad sender or a sunk float on an otherwise-good sender assembly.
Float: Ford P/N COAZ-9202-B
Strainer "sock": GM P/N 5651 705
Gasket: Chrysler P/N 6031 475
Sender grounding clip: Chrysler P/N 2258 862
Could also be a bad wire between sender and dash, though.
Author:  65Dodge100 [ Mon May 07, 2012 11:20 am ]
Ford seems to have lost their minds on fuel sender floats. One dealer near me wanted $17 another wanted $19.
I found mine at Auto Krafters, P/N 15309, for $6.95/$11 and change with shipping:
http://tinyurl.com/7cpcn6h
My old one is still rattling around in the tank behind the seat where I dropped it along with a fish net I was trying to retrieve it with. One day I'll get time to remove the tank and dump them both out.
Danny
Author:  SwingerGrrl73 [ Thu May 31, 2012 1:28 pm ]
I'm having the same issue with my Vera. Also a 65 with the gas gauge pegged at E.....Now, when you replace the sending unit, does the tank have to come all the way out?
Author:  mcnoople [ Fri Jun 01, 2012 5:35 am ]
It should come out by supporting the body on the rear frame rails and letting the axle drop out of the way.
Author:  Mroldfart2u [ Fri Jun 01, 2012 5:57 am ]
Danny
Not to be a smart a** , so you "saved" how much money? my math has been slipping lately.. but if was for the lack of wanting to 'give' money to FoMoCo, I guess thats ok also...
