| Diff Swap From 74 Valiant To 65 Dart? https://slantsix.org/forum/viewtopic.php?t=40026 |
| Author: | RACE GENTRY [ Thu Apr 29, 2010 2:46 pm ] |
| Post subject: | Diff Swap From 74 Valiant To 65 Dart? |
Can I swap 48k valiant rearend into to my wore out 146k dart both auto slant 6, also will front spindles swap? Thanks |
| Author: | dookdart [ Thu Apr 29, 2010 6:09 pm ] |
The rear is a straight swap. The bolt pattern will now be LBP though. If you bring over the front disks....you need to do the FULL swap. UCA, spindles, shields, calipers, prop. valve, hoses and MC. LCAs are fine. If your 74 is a power brake car, the MC is not the same as a manual pushrod. |
