It is currently Fri Nov 20, 2026 2:52 am
PostPosted: Wed May 05, 2010 7:50 am
Hey All,
This is a long post, but I am trying to get my slant in racing shape for the May 2010 Mason Dixon race. Thank you for any insight or help.
I am getting a vibration which feels like it is coming from the driveshaft/rearend of my dart. It starts around 50/60 mph and really starts being a nuisence at 80/85 mph. The vibration is worst when I am in that small area between accelerating and coasting. It really starts shaking then. If I hit the gas or coast it subsides just a bit.
The car is a /6, 4 speed OD, 8.25 rear professionally built w/4.10 gears. The drive shaft was built last year at a local shop using a new tube and yokes I had on hand. It was balanced at that time (of course). The car also has SS rear springs, and I converted the trans mount from the old style to the newer spool style. To measure the length for the driveshaft I pulled the yoke out of the transmission unitl I had 3/4 of an inch from the radius on the yoke to the dust boot. I think the finished product may actually be just over 3/4 of an inch out of the trans (from the dust boot, not the seal) though.
I was thinking this was a driveshaft angle problem.
I made a angle checking tool out of a protractor, string and a magnet. I check the driveshaft angles at the rear and trans, and they didn't seem all that out of whack, but I forget the measurements. I am going to take them again this weekend.
How do you adjust driveshaft angle at the trans end with the spool type trans mount? I know with the old style mout there were shims. Should I put my old style mount back in there and fool with the shims?
What else should I be checking? Tires are new, wheels are in good shape and balanced.
Thanks for ANY thoughts or ideas!!!
Chris
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
 Post subject: vibration
PostPosted: Wed May 05, 2010 1:48 pm
U joints are new/good? Is the rear joint in the yoke properly? No crude or other stuff not letting it seat fully? Jack it up remove wheels, run a couple lug nuts on to hold the drums on. Put in gear and check if there is any obvious wobbling of the drum or can you see the face of the axle wooble when turning.
I'm sure others much smarter than I will chime in.
Rick
Chris. Is your engine capable of spinning to 6000 RPM? If so you have entered the scary zone as far as the stock clutch and P&P. I would say at 5000 your safe 5500 Iffy and 6000 on the edge. This is all just a gut feeling from someone who has had an explosion. I had flat shifted my car hundreds of times at 6200-6500 RPM and never had a problem. But when it did have a problem (1-2 shift @6500) it was not pretty. I feel very blessed to have no injuries from my incident.
Greg & Doc I'm sure will give their advise also.
Rick
PostPosted: Wed May 05, 2010 2:21 pm
Is the slip yoke in good condition and inserted deep into the rear of the transmission? is there any "slop" when pushed sideways? (worn bushing in the tailshaft)
You may want to try moving the driveshaft into a different position, (180 degrees) to see if anything changes.
PostPosted: Thu May 06, 2010 10:00 am
Yes the u-joints are brand new and were installed when I had the driveshaft balanced. I'll check the installation again this weekend.
I am worried a bit about the yoke depth in the trans. Again, I measured from the dust boot not the inner seal. Was that right? I have it 3/4 inch or just slightly more, sticking out from the dust boot.
Gosh I hope that is right and not the problem. That stupid tube sure did cost me and I can't make it longer!
Thanks for the ideas and suggestions. i am going to try them this weekend.
CE
 Post subject: Driveshaft
PostPosted: Thu May 06, 2010 1:59 pm
Chris, I don't know the answer to the question, but I'm sure Doc will let you know. If it turns out it is too short, give me the center to center u-joint length on yours and we may have one you can use.
Rick
PostPosted: Thu May 06, 2010 8:21 pm
Good Luck Finding your Problem, If worse comes to worse you'll have about 20 Slant gearheadz over at your place in 3weeks to help you out.
I most certainly will stop to help!
PostPosted: Fri May 07, 2010 10:20 am
Could be angles when you installed new trans mount, but hard to see that when it's a factory late style mount and X-member.
Bad pinion bearing?
Could be other loose stuff in car that is amplifying a small vibe?
If it's coming only around 80 MPH under those conditions, I'd say you're probably fine for the track. You likely will not run faster than that. Shifting at 5000 is where I'd start, or even a bit lower. If I ride in the car before racing, I can give you estimated shift points and listen to vibration.
Ciao babe,
PostPosted: Fri May 14, 2010 6:09 am
Hey All, thanks for all the ideas.
I had the driveshaft balance re-checked this week and it is good. There is a little play in the yoke/trans end, but nothing more that any of my other vehicles. The yoke bushing in the trans was replaced when the trans was rebuilt by Passon perf.
The pinion bearing is brand new too and there is no play.
I can feel the very slight beginnings of wear/striations around the yoke. They are centered on one 180 degree section and most of the wear is on a 45 degree section. This must be the beginnings of wear from the vibration. It is fairly evident visually (as a scuff) but you can barely feel the wear when dragging your fingernal over it.
I am totally convinced this is from the vibration. I am also convinced at this point it is from a the shaft being too short.
Rick Covalt was nice enough to loan me a shaft which is 1.5 inches longer. I am going to put my yoke on it and see how it fits. If that is too long one of my friends has a C body shaft he is going to give me. I think there will be time to get this thing cut, welded and balanced by next weekend if I have to.
Nothing like going right down to the wire!!!
PostPosted: Fri May 14, 2010 6:59 am
Hm. From your description, it sounded like your shaft was the right length. If it is 2" too short, that could do it.
PostPosted: Fri May 14, 2010 7:49 am
I thought it was too, but now I am not so sure. I pulled the yoke 3/4" back from the dust boot and had the driveshaft made to that length. I guess I had the car supported wrong b/c the driveshaft stuck more than 3/4" out after I had the finished product.
The yoke is only 5" long. If I take into consideration the length of the dust boot, there is only 2.5" of yoke actually in the trans. I'm thinking half of the yoke ain't enough.
We'll likely find out tonight after work!
C
PostPosted: Sat May 15, 2010 4:45 pm
Boy am I feeling defeated! Ugh. :(
I put in a driveshaft today that Rick C loaned me and buttoned up a couple of other things I had to do. The driveshaft was 1.5 in longer than the one I was using. Now I have only .5 of an inch of yoke sticking out of the trans.
The vibration problem is about 50% better but it isn't gone. But then I have no way of knowing that Rick's ds is balanced correctly either. UGH!!!
I think it is good enough to run at Mason Dixon but I'd sure like to get this problem FIXED!
Maybe I need to buy a real angle finder for the U joints. I was using one I built from a protractor and a magnet. Who knows........
I am going to have a longer ds put together and balanced this week if I can.
One positive is that I found out the secondarys on the carb were not opening fully. I got that squared away and the car is a bit more snappy :) I'll call that the silver lining :)
C
 Post subject: Couple questions...
PostPosted: Sat May 15, 2010 7:38 pm
At 55/60 are you in overdrive or direct(3rd)?
What kind of spool mounts are you using (old rubber/stock india replacements/poly?)
Is the tranny mount rubber or poly?
When you are inbetween coast and "gas"... have you cut the ignition and checked your spark plugs immediately?
PostPosted: Fri May 21, 2010 11:36 am
Ok, at least it is good that my auto mechanic senses haven't completely abandoned me since my dealership days.
The new longer, balanced drive shaft fixed 90-95% of the vibration. Yay!
I think the 5% or so that is left (at 80+ mph) is a combo of smaller things.
Thank you very much for all the help!
