| Just had to share https://slantsix.org/forum/viewtopic.php?t=40171 |
| Author: | sharpsj [ Mon May 10, 2010 9:19 am ] |
| Post subject: | Just had to share |
All, I recently had an experience I just have to share. I bought a 69 Valiant going on 3 weeks ago. It ran when I bought it, though roughly. And it continued to run for quite a while. Eventually, I had a mechanically inclined friend over to look at the project. He opened the hood, and said,"You sure this thing runs?" The ignition coil was wired WRONG- not just backwards, but the negative went to the distributor,and there was no positive attached. So the several times I started the car it was apparently running by dieseling. Or on hope and dreams... Just a reminder to check EVERYTHING when buying a car. |
| Author: | KBB_of_TMC [ Mon May 10, 2010 9:41 am ] |
Out of curiosity, is the coil shorted internally? In other words, what was the coil-to-ground resistance? I'm very surprised it would start! |
