any one know what color speedo gear?
https://slantsix.org/forum/viewtopic.php?t=40229
Author:  ValiantOne [ Fri May 14, 2010 6:26 am ]
Post subject:  any one know what color speedo gear?
I'm running a 833 O/D and a 4.10 rear.
I seem to remember someone telling me it is the white gear?
Yea / nay?
Thanks!
Author:  FrankRaso [ Fri May 14, 2010 9:37 am ]
The correct gear also depends on your tire size. There are calculations on the Tire Upgrade page.
Author:  wjajr [ Fri May 14, 2010 11:17 am ]
Year One also has a gear sizeing chart listing tire size & rear end gear ratio as well as gear color located in the transmission section. If you need to get a different sized gear, search the net for a good buy as prices are all over the map on these devices.
Author:  Fopar [ Fri May 14, 2010 3:58 pm ]
Check out
http://www.tciauto.com/Products/TechInf ... _gears.asp
