Carb ID help for forum newby
https://slantsix.org/forum/viewtopic.php?t=40234
Author:  kimcadmus [ Fri May 14, 2010 3:23 pm ]
Post subject:  Carb ID help for forum newby
Help with carb id please!?! I spent a lot of time online today including this forum but could use some help. It is on my '83 Dodge Ram D150 and I need to order a rebuild kit.
Here are picsImage
numbers on body read
6R 5571 B
4287033
40056
2232
another Image
Thanks,
Kim
Author:  Aggressive Ted [ Fri May 14, 2010 3:29 pm ]
It's a Holley 1945 used in a variety of versions from 1974 on....
Author:  kimcadmus [ Fri May 14, 2010 4:04 pm ]
Thanks Ted for the speedy response! May I ask how you determined the model?
Author:  SlantSixDan [ Fri May 14, 2010 4:51 pm ]
Visual ID is easy once you've wrenched on these cars enough to spot the various details. Welcome on the board. Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
Specifically, your carb is original to a 1983 Dodge Truck/Van with catalytic converter and electronic spark advance. If it's not the vehicle's original carb (which it probably is), it's the correct one. Try to get a Walker kit (number 15560D ); they're the best-quality mass-market kits out there. While you're in there, replace the Nitrophyll foam float with a brass one (Walker number 100-48 ); they're more resistant to the reformulated gasolines available today. If you can't find Walker kits and parts locally, contact them directly.
Welcome on the board!
Author:  Aggressive Ted [ Sat May 15, 2010 1:07 pm ]
kimcadmus,
I own 4 or 5 of these carbs, all original no after market rebuilds and have tried to see if I could get some good performance mileage from them. Like Dan says, they become familiar after you work on a few.
Author:  kimcadmus [ Mon May 17, 2010 5:34 pm ]
Ted and Dan,
Thanks for all the great info. I was able to get the kit and float just down the street from me from O'Reilly's. I hope fix it up this week. The links you posted Dan I'm sure will be very useful. I'll post my results.
Best Regards,
Kim
