| Clutch cross shaft https://slantsix.org/forum/viewtopic.php?t=40241 |
| Author: | Exner Geek [ Sat May 15, 2010 6:07 am ] |
| Post subject: | Clutch cross shaft |
I finally got the white 62 Valiant running in preparation for the trip to Maryland next weekend. First thing to do was to fill the gas tank so I know where I am starting from. I drove over to Sam's Club marveling at how much quieter the car is with the transmission tunnel and carpet installed! After I fill up, I push in the clutch and start the engine only the clutch is still engaged, I put it in neutral and start the engine but the clutch pedal stays on the floor, oh oh. Some bystanders helped me push the car out of the way into the parking lot so I could determine what happend. Fortunatley I still had my tools and spare parts in the car from the last time I went racing. I pulled the inspection plate and the relaease fork looked okay. It looked like the crossshaft wasn't rotating the arm far enough to the rear to work the fork. I felt around and sure enough I could feel torn metal where the clutch arm is welded to the cross shaft. I have always thought that this is one of the most over stressed and poorly designed parts on these cars but it had lasted almost 50 years, some of those pushing on a 2,200# Weber clutch. Fortunately I had a couple of spare cross shafts with me but only one had been shortened to work with the pivot on the Volare bellhousing. I managed to changed it in less than an hour, Lou and Charlie would been proud. Seemed to work fine afterwards although I noticed that the adjustable link I had been using was now too long and the cltuch released much higher than before. I imagine that arm had been starting to rotate before it failed. I am really glad this happend at home and not along the I 80 in Gary, IN. I will shorten that other cross shaft and bring it along just in case. Has anyone come up with a good method of strengthening this piece? I laid awake last night thinking about it, what if you made a gusset sort of in the shape of a tear drop with a key hole cut into it? Then you could weld it along the back side and help to distribute the twisting forces. Anybody ever do this or make another modification that worked? The rush you get from having to respond to a problem like this is extremely energizing! |
| Author: | dakight [ Sat May 15, 2010 6:25 am ] |
I had this exact same failure 2 or 3 times when I had my first '62. After buying new parts the first couple of time, I took the bar off and straightened the arms as best I could. I them took some large steel washers and bored out the center hole to fit over the shaft. I then ( well actually my dad ) welded the washers to the main tube all the way around on the back side and around the frint side and along the contact point of the arms. I did this on both ends and it never failed again. This is pretty much the same idea as your tear-drop gusset, just not as pretty. |
