It is currently Fri May 08, 2026 4:17 am
 Post subject: Fuel Line Numbers?
PostPosted: Sun May 16, 2010 3:50 pm
HELLO I JUST BOUGHT A JAZ FUEL CELL 200 -10 with the red cap,i was tinking to used the existing fuel lines but the fuel cell goes in the trunk so i need like seven feed of line, to know what gas line numbers to use and fittins,thank you the car is a 72 duster
PostPosted: Mon May 17, 2010 2:29 am
The fuel cell, I just installed in my car, has #8 fittings for the outlets, to the fuel pump. Caped one fitting, and ran a 18 inch braided #8 line to the fuel pump inlet. Aluminum 3/8 line from the pump to the filter, and the 3/8 aluminum line to the pressure regulator in the engine compartment. Then #6 braided from the regulator to the carb/nitrous system.
Users browsing this forum: Bing [Bot] and 9 guests
