It is currently Fri Nov 20, 2026 12:22 am
 Post subject: Third member options
PostPosted: Sat May 15, 2010 10:13 pm
I have an 8.75 from a 68 dart that is #742. What other centers can I use or do I have to stay with the same #? Thanks for any input.
PostPosted: Sat May 15, 2010 11:44 pm
You can also use 489 or 741 cases. Just make sure they have the right yoke size. A 657 case will also work, but the floating thrust block might have to be changed.
PostPosted: Sun May 16, 2010 8:25 am
Thanks Josh :)
