| Raising a D 150 https://slantsix.org/forum/viewtopic.php?t=40251 |
| Author: | tlrol [ Sun May 16, 2010 7:55 am ] |
| Post subject: | Raising a D 150 |
Anyone one raise their D-150? I have a 1982 D-150 that was saggy in the rear. I threw in an add-a-leaf in the back and a 1" rubber spacer in the front. It works, rides a bit rougher without a load in it, but I wonder what other options are out there. I think that 3/4 ton springs could be used which presumably would lift it. What about 1 ton springs, etc? How much of the D series is "plug and play" across the 1/2 ton, 3/4 ton, 1 ton for suspension stuff? |
| Author: | hantayo13 [ Mon May 17, 2010 6:14 am ] |
when i raised back of mine ...i got another set of springs and built my own spring stack...rode a bit rough empty...but could load a ton and not drop more than an inch |
| Author: | hantayo13 [ Tue May 25, 2010 5:39 am ] |
a good spring shop can re arch springs..... body lift kits are out there |
