| Fuel Line Numbers? https://slantsix.org/forum/viewtopic.php?t=40257 |
| Author: | lordduster888 [ Sun May 16, 2010 3:50 pm ] |
| Post subject: | Fuel Line Numbers? |
HELLO I JUST BOUGHT A JAZ FUEL CELL 200 -10 with the red cap,i was tinking to used the existing fuel lines but the fuel cell goes in the trunk so i need like seven feed of line, to know what gas line numbers to use and fittins,thank you the car is a 72 duster |
| Author: | Charrlie_S [ Mon May 17, 2010 2:29 am ] |
The fuel cell, I just installed in my car, has #8 fittings for the outlets, to the fuel pump. Caped one fitting, and ran a 18 inch braided #8 line to the fuel pump inlet. Aluminum 3/8 line from the pump to the filter, and the 3/8 aluminum line to the pressure regulator in the engine compartment. Then #6 braided from the regulator to the carb/nitrous system. |
