| front seal replacement on 9 1/4 rear? https://slantsix.org/forum/viewtopic.php?t=40309 |
| Author: | hantayo13 [ Wed May 19, 2010 1:57 pm ] |
| Post subject: | front seal replacement on 9 1/4 rear? |
do i need to replace crush sleeve???? or can i just remove nut ,yoke ????...r&r seal replace yoke,nut & torque |
| Author: | emsvitil [ Wed May 19, 2010 2:47 pm ] |
You could always mark the nut, then count how many turns it takes to get it off.... Then when reinstalling, just put the nut back to it's original spot.......... |
| Author: | hantayo13 [ Tue May 25, 2010 5:30 am ] |
is this really that simple???? |
| Author: | Doc [ Tue May 25, 2010 8:39 am ] |
Yes... I have successfully removed and re-installed the yoke on a C.S. type rear with-out problems. You just have to be careful to no over or under tighten the nut upon re-installation. The main pinion bearing position is set by a solid shim on a CS set-up so gear mesh change is not the issue. The crush sleeve sits between the front and rear pinion bearings and takes-up the slack / sets the preload on those bearings. Marking the position, nut to pinion shaft & counting the nut's turns upon removal, helps take some of the reinstall guess-work out of it. Slowly bringing the torque back up to spec, while checking bearing clearance, (side-to-side "wiggle" and rotational friction) helps you find your way back to the correct tightness. Get it to loose, the nut looses torque, comes-off and the grears "crash" together. (self-distruction) Get it to tight, the pinion bearings burn-up. In real world, it is better to have it a little tight, then a little loose. What I usually find, is that the reinstall torque goes back to the listed factory spec. and then I put another 5 ftlbs on top of that, and it's good. DD |
| Author: | hantayo13 [ Tue May 25, 2010 9:55 am ] |
thank you doc that the info I was looking for keep on roddin' |
