| How do I remove the spark plug washers? https://slantsix.org/forum/viewtopic.php?t=40320 |
| Author: | Schneiderman [ Thu May 20, 2010 2:36 pm ] |
| Post subject: | How do I remove the spark plug washers? |
Seems so simple... apparently it's not. First I tried threading them off as I have seen Dan mention and they don't want to follow the threads. Then I tried cutting it off and I can't get snips in there. Advice? If I am indeed supposed to thread them off, how do I grab them to do it? These are NGK ZFR5N plugs. |
| Author: | Joshie225 [ Thu May 20, 2010 2:39 pm ] |
I grab the washers with needle nose pliers and twist them off, but I'm just mean like that. |
| Author: | Schneiderman [ Thu May 20, 2010 4:30 pm ] |
I got it, I was just being too careful, afraid to damage the threads. I did it by grabbing them around with big pliers, squeezing tight and using a ratchet to turn the plug. The threads may have taken a little bit of a hit but the plugs went in fine and the engine runs great. |
| Author: | ceej [ Thu May 20, 2010 4:35 pm ] |
I just grab them with an old set of side cutters, snip, then grab them again and twist the side cutters. They come right off. CJ |
| Author: | ESP47 [ Tue May 25, 2010 10:48 pm ] |
I use a small pair of electrical flush cutters. |
| Author: | SlantSixDan [ Tue May 25, 2010 10:56 pm ] |
I span them with slip-joint pliers and simply unscrew them. |
