'63 PB904 trans info needed
https://slantsix.org/forum/viewtopic.php?t=40335
Author:  hellion_locdogg [ Fri May 21, 2010 3:47 pm ]
Post subject:  '63 PB904 trans info needed
I'm in the middle of my teardown starting last night. I need to know the band adjustments, I know they are different from early to late models. I do have a book that calls for 72 in lbs then out 2.5 low and 4 high. Also for kickdown adjustment on valve body it calls for a gauge tool, anybody know the dimension for that? I can use gauge blocks if needed.
Trans looks good except for the high band drum, ouch. I brought it to work to turn it on the lathe. It looks to be a groud surface but I'm sure I can get a good finish on the lathe. Some of the friction plates were actually deteriorating, not worn just falling apart. I suspect that is what happened to the high band, it sure chewed the drum.
Should have it back together in a snap. Was not as nearly as intimidating once I got into it. Thank God for an arbor press and manuals.
,Cliff
Author:  hellion_locdogg [ Tue May 25, 2010 6:51 pm ]
Anyone? Are they the same? Remember seeing that they were different.
,Cliff
Author:  SlantSixDan [ Tue May 25, 2010 7:17 pm ]
See here
Author:  Fopar [ Tue May 25, 2010 7:45 pm ]
Adjust with 1/8" drill between arm and plunger :)
Author:  hellion_locdogg [ Tue May 25, 2010 8:05 pm ]
Got the kickdown adjustment, thanks though. Need to know band adjustment.
,Cliff
Author:  Fopar [ Tue May 25, 2010 9:09 pm ]
2 1/2 front and 4 on rear :)
Author:  hellion_locdogg [ Tue May 25, 2010 9:20 pm ]
Ok, so it is the same as a later model? I thought that I had see that it was different between the two!? I obviously don't remember the difference though. LOL Thanks Fopar...
,Cliff
