| what holly 1 barrel carb is best for my 72 dart? https://slantsix.org/forum/viewtopic.php?t=40346 |
| Author: | butch crawford [ Sun May 23, 2010 12:06 am ] |
| Post subject: | what holly 1 barrel carb is best for my 72 dart? |
i purchased a new rebuilt after market 1920 holly carb for my 72 dart 198 ci motor.i hate it.starts ok,runs great for awhile,but most of the time i have to goose or feather it at stop signs,light,etc.it wants to stall,than other times at redlights it wants to take off by itself,idols faster.i have to hold the break on or put it in neutral.what could be the problem with this carb?what do you guys recommend as a new replacement carb,not rebuilt.does anyone know the correct original numbers of the 72 factory carb? i have a near by junkyard that has 5/6 darts in it,some have carbs on them. any help would be appreciated. butch |
| Author: | 6shotvanner [ Sun May 23, 2010 9:27 am ] |
Sounds like you found out(the hard way=wasted $)what most here will tell you and that is...Store bought rebuilt carbs are junk! You might try a PM to SlantSixDan as he did have some brand new(not rebuilt)carbs,I don't know how his supply is holding up though.Next best is picking up a rebuildable carb or two and either have a reputable carb shop make you a good carb or tackle the job yourself.Check the 'stickys' at the top of the forum for carb rebuild/tuning info.Good luck |
