a 904
https://slantsix.org/forum/viewtopic.php?t=40357
Author:  aspen jim [ Mon May 24, 2010 8:40 am ]
Post subject:  a 904
I am wondering if anyone can tell me if an A904 from a 77 will work in an 78 ? Is the only differance the Lock-up Converter , or will I have to buy a Non Lock -up for it . Thank You Jim
Author:  Shaker223 [ Mon May 24, 2010 9:24 am ]
Converters are different between the two.
Author:  Charrlie_S [ Tue May 25, 2010 5:30 am ]
Just use the converter that goes with the trans. Lockup converter with lock up trans, or a non lock up converter with a non lock up trans.
Author:  plymouthhillsidehemi225 [ Tue May 25, 2010 4:31 pm ]
Not to steal your question but this is relevant... If they started with the lock up converters in 78, and my car is a 78 model without a lock up, would that be only because it was built in february of 77? I also own a 79 aspen (parts car) that has a lock up converter, would there be a problem with swapping the converters or would it require the whole different tranny? If so, why?
Author:  Doc [ Tue May 25, 2010 4:54 pm ]
You have to swap the complete transmission.
There are a number of differences between the L-up & non L-up trannys, besides the converter, the input shaft spline count , oil feed holes and valve body are different.
