904 Tail swap?
https://slantsix.org/forum/viewtopic.php?t=40366
Page 1 of 1
Author:  hellion_locdogg [ Mon May 24, 2010 4:10 pm ]
Post subject:  904 Tail swap?
Anyone ever try to swap a later 904 tail housing and shaft to early PB904?
I have one of each and tail bushing and seal on the PB are hard to find. Plus I would gain the benifits of a slip yolk and ditch the B&T.
,Cliff
Author:  Doc [ Mon May 24, 2010 4:22 pm ]
This swap does not work.
The cable shift (60-65) 904 has two oil pumps, front & rear.
The rear pump is driven by the output shaft. It would take some major work to get the later output shaft to accept the rear pump's impeller.
Author:  hellion_locdogg [ Mon May 24, 2010 4:33 pm ]
You are correct sir, I now remember seeing the pin in the shaft that drives the rear pump. Just a thought. Any idea on other parts that may swap?
,Cliff
Author:  SV162 [ Mon May 24, 2010 6:46 pm ]
Another way to ditch the B&T is to modify the drive shaft. I've had the B&T joint cut off the front of mine and it's been replaced with a slip yoke and uni joint that bolts up to the original B&T flange on the trans. Does that make sense??
Here's a pic.
Author:  hellion_locdogg [ Mon May 24, 2010 6:54 pm ]
Yes, I have seen this mod and have the parts list for it. Jut a PIA find my bushing and seal. Shopped hard and found a few places in town.
These guys have all my parts and a TC. http://www.transtarindustries.com/
,Cliff
