power steering
https://slantsix.org/forum/viewtopic.php?t=40378
Page 1 of 1
Author:  terrylittlejohn [ Tue May 25, 2010 5:14 pm ]
Post subject:  power steering
a fellow slantsixer came by today and has a 64 slantsix valiant with manual steering , he wants power steering , all the parts i have are from 67 to 76 . does anybody know if it possible to swap these parts into a 64?
Author:  65 dartman [ Tue May 25, 2010 5:49 pm ]
He'll need at a minimum the center shaft from a PS-equipped 64-66. Might be easier to find a complete column though.
Author:  Fopar [ Tue May 25, 2010 5:53 pm ]
Isn't there a difference in the pitman arm ??
Author:  SlantSixDan [ Tue May 25, 2010 6:59 pm ]
Yes, the pitman arm is '62-'66 only.
Steering box is '62-'72 A/B-body
Steering column or steering shaft will need changed (shorter)
P/S pump and brackets from '67-up cars do not necessarily fit easily in '66-down cars -- they'll bolt up to the engine just fine, but may not leave enough room for P/S belt adjustment without hitting the inner body metal.
Author:  terrylittlejohn [ Wed May 26, 2010 4:02 am ]
so will the pitman arm of the standard box from the 64 fit the power steering box from 67 to 76, are the splines the same?
Author:  SlantSixDan [ Wed May 26, 2010 9:38 am ]
Again: Steering box is '62-'72, A/B-body. You cannot use a '73-up power steering box, which will not connect to the '62-'66 pitman arm.
Author:  Avenger2040 [ Thu Jul 15, 2010 1:30 pm ]
Sorry to bring back a old topic but got a question in this matter, I got a 71 Duster and got everything but the steering column or steering shaft from a 75 Duster to get power steering.
The power steering box will fit and install without problems?, will I need other thing to modify appart the steering column and/or steering shaft?
Thanks in advance!
Author:  Joshie225 [ Thu Jul 15, 2010 1:42 pm ]
If you're using parts from a '75 on your '71 you'll need to transplant the steering box, pitman arm, idler arm and center link. You'll also need a steering column or the shorter shaft used with power steering.
