It is currently Mon Dec 29, 2025 3:38 am
PostPosted: Thu May 20, 2010 2:36 pm
Seems so simple... apparently it's not. First I tried threading them off as I have seen Dan mention and they don't want to follow the threads. Then I tried cutting it off and I can't get snips in there. Advice?
If I am indeed supposed to thread them off, how do I grab them to do it?
These are NGK ZFR5N plugs.
PostPosted: Thu May 20, 2010 2:39 pm
I grab the washers with needle nose pliers and twist them off, but I'm just mean like that. :D
PostPosted: Thu May 20, 2010 4:30 pm
I got it, I was just being too careful, afraid to damage the threads. I did it by grabbing them around with big pliers, squeezing tight and using a ratchet to turn the plug. The threads may have taken a little bit of a hit but the plugs went in fine and the engine runs great.
PostPosted: Thu May 20, 2010 4:35 pm
Site Admin
I just grab them with an old set of side cutters, snip, then grab them again and twist the side cutters. They come right off. :D
CJ
PostPosted: Tue May 25, 2010 10:48 pm
I use a small pair of electrical flush cutters.
PostPosted: Tue May 25, 2010 10:56 pm
I span them with slip-joint pliers and simply unscrew them.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
