It is currently Fri Nov 20, 2026 10:43 am
PostPosted: Fri May 21, 2010 3:47 pm
I'm in the middle of my teardown starting last night. I need to know the band adjustments, I know they are different from early to late models. I do have a book that calls for 72 in lbs then out 2.5 low and 4 high. Also for kickdown adjustment on valve body it calls for a gauge tool, anybody know the dimension for that? I can use gauge blocks if needed.
Trans looks good except for the high band drum, ouch. I brought it to work to turn it on the lathe. It looks to be a groud surface but I'm sure I can get a good finish on the lathe. Some of the friction plates were actually deteriorating, not worn just falling apart. I suspect that is what happened to the high band, it sure chewed the drum.
Should have it back together in a snap. Was not as nearly as intimidating once I got into it. Thank God for an arbor press and manuals.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
Last edited by hellion_locdogg on Tue May 25, 2010 6:51 pm, edited 2 times in total.
PostPosted: Tue May 25, 2010 6:51 pm
Anyone? Are they the same? Remember seeing that they were different.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue May 25, 2010 7:17 pm
See here
PostPosted: Tue May 25, 2010 7:45 pm
6 Pack Dart
Adjust with 1/8" drill between arm and plunger :)
PostPosted: Tue May 25, 2010 8:05 pm
Got the kickdown adjustment, thanks though. Need to know band adjustment.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue May 25, 2010 9:09 pm
6 Pack Dart
2 1/2 front and 4 on rear :)
PostPosted: Tue May 25, 2010 9:20 pm
Ok, so it is the same as a later model? I thought that I had see that it was different between the two!? I obviously don't remember the difference though. LOL Thanks Fopar...
,Cliff
'72 4 dr Dart
'63 4 dr Dart
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
