It is currently Fri Nov 20, 2026 2:48 pm
 Post subject: a-833 shaft "play"
PostPosted: Tue May 25, 2010 8:09 pm
looking at an a-833,, its local so there would be no shipping charges,,
owner does not know much about it,,
it has an iron case, short tail shaft,
one thing, there is more than a little side to side play on both the input and output shafts,, I expect a 40 year old transmission to need a re build,, would the play in the shafts indicate a problem that would be beyond a normal re build....
thanks
PostPosted: Wed May 26, 2010 9:08 am
Some side play at the shafts is normal.
Is this an Overdrive unit?
PostPosted: Wed May 26, 2010 3:04 pm
seller says the tranny was from a 68 340 Dart,, that got totaled, from there it was being installed in a 73 Duster but that project was never fininshed,, tranny was roughed in but never finished,, that car sat for a couple of years and then was sold,,,the current owner of the Duster is changing it back to an auto. The info on the tranny is what was told to him by the previous owner of the Duster.......
I'll see if I can get the casting / and stamped numbers off it
there is a "greasy" stain on the front and rear shaft openings, so there is signs of some fluid leakage.
about how much side to side / up down play is normal
thanks
PostPosted: Thu May 27, 2010 5:51 pm
numbers on the transmission pad are
CB291605
PP833 3092 185
how are these read to establish the mfg date,, ratios ,,,,
thanks
