It is currently Fri Nov 20, 2026 2:29 pm
PostPosted: Tue May 25, 2010 7:37 pm
Hi there,
I have a 79 Volare, slant 6 (obviously), automatic with 104000km on it. The issue I am having is this:
When I put it into reverse, it stalls out. This will happen whether its hot or cold. Goes into D, 1, and 2nd without any problems. No stalling at lights or anything like that. I have found that if I am persistent, I can get it to go into R, but it will be very rough, and respond only to very light acceleration. If I give it too much gas, it stalls out. There is also a rattling sound coming from beneath the vehicle, but only when its in reverse. This is probably due to it running roughly, but perhaps worth mentioning.
Sorry if this is in the wrong place, it just seems like the most appropriate section.
If anyone could give me some insight into the problem, ease of fixing it myself, and/or what I would be getting into at a shop, I would be so very appreciative.
~Scott
PostPosted: Tue May 25, 2010 9:07 pm
My '79 volare does the same thing,there was a TSB on this when the cars were new.It is caused by leakage on the transmission-torque converter splines,causing the lock-up converter to drag in reverse.It will be worse in hot weather,or if you drove the car for a long distance,and the trans fluid got hot and thinned out. The factory fix was a new converter and front pump assembly.I rebuild 904 and 727 transmissions,and '78,and'79 were the first two years for lock-up,and had LOTS of drivability and relieability problems.My advice is to ignore it untill it breaks,and find an earlier non lock-up trans and converter to rebuild and put in .My car has 215,000 miles on it,and when the trans dies,I have several transmissions I can put in.
PostPosted: Wed May 26, 2010 2:54 pm
I'm going to make a pure guess on this. When you put the trans in reverse, the engine shifts in the opposite direction.
This could be as simple as a bad ground. Somewhere a motor mount is providing an extra ground back to the chassis, but the contact is broken when you go to reverse.
Double check your engine to chassis ground wires, if their OK, let us know, and we'll go on from there.
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Wed May 26, 2010 8:15 pm
Thank you for the prompt reply guys.
I will cross my fingers and check those wires.
~Scott
PostPosted: Thu May 27, 2010 5:48 am
Hi guys, some of the problems may be solved or prevented form happening by using a shift correction kit like this one or maybe this one.
And no, I have no shares in the company, I just like the automatics!
Olaf
Aspenized
