It is currently Tue Jun 02, 2026 5:17 pm
 Post subject: 3" relocater kit
PostPosted: Fri May 28, 2010 8:54 am
Can some one tell me how much wheel well is to be altered after installing this kit in a 67 Dodge Dart....or can i get away with not cutting at all Thanks Rooster
PostPosted: Fri May 28, 2010 3:39 pm
After cutting the unibody frame rail and welding in new spring purches... you will gain about 2 1/2 inches of wheel back space.... You can get some nice 10 inch wheels in before you need to tub... Also look at upper inner well clearance when sizing your tire.
