| Engine Stand https://slantsix.org/forum/viewtopic.php?t=40465 |
Page 1 of 2 |
| Author: | christian_guitar [ Wed Jun 02, 2010 5:50 am ] |
| Post subject: | Engine Stand |
Anyone here on the forum build or know where to purchase engine stands for the /6? I sure could use one. |
| Author: | Joshie225 [ Wed Jun 02, 2010 10:59 am ] |
I've got the big engine stand from Harbor Freight. Mine is older and doesn't fold, but is otherwise very similar. http://www.harborfreight.com/2000-lb-fo ... 67015.html I've had a slant fall when it was on a smaller stand similar to this. http://www.harborfreight.com/750-lb-cap ... 32915.html |
| Author: | christian_guitar [ Wed Jun 02, 2010 11:49 am ] |
Thanks Joshua. Yeah, that small one looks like and accident waiting to happen. I may have to go with the 2000 lbs. stand but what I am really looking for is something that lets me keep the tranny hooked to the motor. Any other suggestions? |
| Author: | Joshie225 [ Wed Jun 02, 2010 12:40 pm ] |
There are engine dollies that allow you to keep the engine and trans bolted together, but they are typically engine specific and sit very low to the floor. |
| Author: | christian_guitar [ Wed Jun 02, 2010 12:52 pm ] |
I noticed earlier, on the ebay hyperpac link, that the seller had his engine on a stand...waiting on a response from him/her. I am having a space problem...running out of...and I currently have the engine and tranny connected to my hoist, so I was looking for something low and with wheels. |
| Author: | Reed [ Wed Jun 02, 2010 1:26 pm ] |
I have seen engine cradles (low to the ground) fabricated out of 2x4 with casters bolted to the bottom. If you have some basic tools you could probably fabricate one yourself. |
| Author: | christian_guitar [ Wed Jun 02, 2010 1:47 pm ] |
Thanks Reed. That's probably what I will end up doing. I may make it out of 4x4 so I can raise it a bit higher. |
| Author: | emsvitil [ Wed Jun 02, 2010 4:19 pm ] |
Quote: There are engine dollies that allow you to keep the engine and trans bolted together, but they are typically engine specific and sit very low to the floor.
I just used a creeper or furniture dolly..........Harbor Freight has a 1000lb stand that has 2 front wheel instead of 1. |
| Author: | christian_guitar [ Wed Jun 02, 2010 6:56 pm ] |
Thanks Ed, I'll check it out. |
| Author: | rustyfords [ Wed Jun 02, 2010 7:10 pm ] |
Quote: Harbor Freight has a 1000lb stand that has 2 front wheel instead of 1. However, it has a small drawback. The double front legs run into the slightly V-shaped base of my engine hoist, and even with the engine hoist boom extended all the way out, I have to get creative to move an engine from the hoist to the stand. |
| Author: | GTS225 [ Wed Jun 02, 2010 7:45 pm ] |
I've got a 1250# rated stand from O'reilly's, and a slant bounces pretty badly on it, too. I made my own stand out of 3", 1/4 wall square......nice and solid, now. Do NOT get a three-wheel stand....get a four-wheel stand. Those three-wheelers will dump your engine over on the floor. I built a dolly for an engine/trans assembly from simple 1.5" square tubing. Built it in a three-wheel configuration, two wheels forward under the engine brackets, and a steering caster under the trans mount. I'll see what I can't do to get a pic posted sometime tomorrow. Roger |
| Author: | christian_guitar [ Thu Jun 03, 2010 5:07 am ] |
Rusty, thanks for the suggestion and what to watch out for. I hadn't even thought about the legs of my hoist getting in the way. |
| Author: | christian_guitar [ Thu Jun 03, 2010 5:08 am ] |
Roger, I look forward to seeing the pictures of your stand. Thanks. |
| Author: | 64 Convert [ Thu Jun 03, 2010 5:17 am ] |
I saw a neat build and run stand on one of the television car shows last weekend. It even folded up to take up less space, but I don't recall if you could mount the transmission. |
| Author: | christian_guitar [ Thu Jun 03, 2010 5:27 am ] |
I found the below link for plans to build a folding start stand: http://cgi.ebay.com/ebaymotors/Engine-S ... 35a9cb1e58 |
| Page 1 of 2 | All times are UTC-07:00 |
