It is currently Fri Jan 02, 2026 4:12 pm
 Post subject: Dutra Duals
PostPosted: Mon Jun 07, 2010 6:46 am
I need a set of slightly used Dutra Duals with the heat riser rear manifold for a high starter 225 in my '79 D100. Could also use a 2bbl intake.
I missed out on a set last December, stilll new in the box.
I can't afford to buy new ones at this time. Sorry, Doug! I have a cracked manifold and don't want to take the time to put on another stock one when I want to split it anyway! Also, my original 1bbl is shot.
Thanks. Tony Keeler, Indianapolis.
PostPosted: Mon Jun 07, 2010 8:38 am
You may have trouble finding a used set of Dutra Duals, but maybe not.
I would suggest saving your money, which may not be easy (I know), and buying a new casting from Doug. Then you can modify your cracked exhaust manifold.
But maybe you'll find a used set.
'78 Volare 225
'67 Charger 318
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 9 guests
