It is currently Wed May 06, 2026 4:44 am
 Post subject: 4-speed identification
PostPosted: Wed Aug 14, 2002 11:11 am
I have a 4-speed trans from a 69GTS but I don't know for sure does any one have the codes?
courtnb@novachem.com
PostPosted: Wed Aug 14, 2002 9:46 pm
: I have a 4-speed trans from a 69GTS but I don't
: know for sure does any one have the codes?
I would bet that it is the 2.66 1st - 1 to 1 4th "close ratio" 833 4-speed.
Get it up on the bench, mark the input shaft and the output shaft and count the turns.
(it helps to slide-in a rear U-joint yoke on the 66 & up units)
Select first gear, (rear shift lever forward) and turn the rear yoke exactly one turn, the front input shaft should turn 2.66 times. (just over 2 1/2 turns)
Here is a handy tip, 3.09 first "wide ratio" 833 have a small ring machined into the input shaft, just before the clutch disc splines, this makes it easy to spot them with-out counting a bunch of turns.
Here is a ratio reference chart:
Users browsing this forum: Amazon [Bot] and 7 guests
