| Dutra Duals https://slantsix.org/forum/viewtopic.php?t=40533 |
| Author: | D100 [ Mon Jun 07, 2010 6:46 am ] |
| Post subject: | Dutra Duals |
I need a set of slightly used Dutra Duals with the heat riser rear manifold for a high starter 225 in my '79 D100. Could also use a 2bbl intake. I missed out on a set last December, stilll new in the box. I can't afford to buy new ones at this time. Sorry, Doug! I have a cracked manifold and don't want to take the time to put on another stock one when I want to split it anyway! Also, my original 1bbl is shot. Thanks. Tony Keeler, Indianapolis. |
| Author: | Wesola78 [ Mon Jun 07, 2010 8:38 am ] |
You may have trouble finding a used set of Dutra Duals, but maybe not. I would suggest saving your money, which may not be easy (I know), and buying a new casting from Doug. Then you can modify your cracked exhaust manifold. But maybe you'll find a used set. |
