| 1966 lift questions https://slantsix.org/forum/viewtopic.php?t=40574 |
| Author: | wayne57 [ Thu Jun 10, 2010 12:19 pm ] |
| Post subject: | 1966 lift questions |
i want to raise my 66 dart front and rear and would like to know the parts or adjustments i need to do this. i like that high gasser look but not to high maybe air shocks for back? thank you for reading this wayne |
| Author: | hantayo13 [ Thu Jun 10, 2010 6:04 pm ] |
add a leaf /rearc rear springs....if air shocks used , need to reinforce mount....tighten torsion bar in front , get realinement done |
| Author: | maxracer21 [ Thu Jun 10, 2010 6:44 pm ] |
| Post subject: | lift kit |
I am 61 and have never seen anything like this ought to lift as high as you want regards max http://cgi.ebay.com/ebaymotors/5532-MOP ... 3c9251[url] |
| Author: | Matt Cramer [ Fri Jun 11, 2010 8:06 am ] |
| Post subject: | Re: 1966 lift questions |
Quote: i want to raise my 66 dart front and rear and would like to know
A traditional gasser would probably have an A100 van solid axle under the front on a fabricated frame. You can also raise a Dart by adjusting the torsion bar bolts on the lower control arms, although the look isn't quite the same. For the rear, use Super Stock springs, and if that's not enough lift, longer shackles. The stock upper shock mounts are not strong enough to take air shocks.the parts or adjustments i need to do this. i like that high gasser look but not to high maybe air shocks for back? thank you for reading this wayne By 1966, you'd often see the front and rear suspension moved forward substantially. See this link for the original example. It also shows the solid axle conversion. http://www.1962to1965mopar.ornocar.com/landys64.html |
