| for the board https://slantsix.org/forum/viewtopic.php?t=40577 |
| Author: | maxracer21 [ Thu Jun 10, 2010 7:02 pm ] |
| Post subject: | for the board |
ever use one of these? http://cgi.ebay.com/ebaymotors/5532-MOP ... 3c9251[url] |
| Author: | brian72valiant [ Thu Jun 10, 2010 11:11 pm ] |
where would this even mount ? only thing I could think of is it goes between the spindle and the upper a arm / balljoint but I dont see how it will help raise up the car any... unless it allows the upper a arm to travel further down before it bottoms out on the bump stops... maby thats it. |
| Author: | maxracer21 [ Fri Jun 11, 2010 4:52 am ] |
| Post subject: | lift kit |
It's a complete mystery to me max |
| Author: | slantzilla [ Fri Jun 11, 2010 2:15 pm ] |
That's a GM ball joint spacer kit. It doesn't raise the front, it allows the front to have more upward travel under launch. I haven't seen one of them since I was in high school. |
| Author: | 2 Darts [ Fri Jun 11, 2010 4:46 pm ] |
Quote: where would this even mount ? That's correct.only thing I could think of is it goes between the spindle and the upper a arm / balljoint Quote: unless it allows the upper a arm to travel further down before it bottoms out on the bump stops... That is it. It can be the difference between putting a front wheel in the air or keeping it on the ground. The latter is real handy on the strip if/when the rear end steps out.
maby thats it. |
