| Engine ID frustration https://slantsix.org/forum/viewtopic.php?t=40586 |
| Author: | 64DartVertible [ Fri Jun 11, 2010 1:36 pm ] |
| Post subject: | Engine ID frustration |
Haven't been able to find my code. Looked from above and below. The engine is clean, so it shouldn't be covered with grease. Do I have to remove the coil to see it? There are five freeze plugs, so I know it's not original to the car. I spent quite a while looking for a picture of an engine showing the code, but the only one I found is this one and it's hard to tell exactly where it is. Dan said in another post: "The numbers needed for engine ID are stamped on a pad facing the sky at the top of the block below the frontmost spark plug, inboard of the alternator lower support/coil bracket." Below the second freeze plug it has 530-8 Below the third and fourth is a little plate that has 1188: held on with screws. What looks like AAWJ is embossed below that. Anybody know what that means? On the passenger side between the fuel pump and oil pan, I found what looks like info about what shift the employees were on when the block was cast. |
| Author: | Fopar [ Fri Jun 11, 2010 1:55 pm ] |
See this post it has a picture. http://www.slantsix.org/forum/viewtopic.php?t=40010 |
| Author: | ceej [ Fri Jun 11, 2010 2:19 pm ] |
And another photo of where the stamped number is. CJ |
