It is currently Sun Jun 07, 2026 5:34 am
 Post subject: for the board
PostPosted: Thu Jun 10, 2010 7:02 pm
ever use one of these?
http://cgi.ebay.com/ebaymotors/5532-MOP ... 3c9251[url]
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Thu Jun 10, 2010 11:11 pm
where would this even mount ?
only thing I could think of is it goes between the spindle and the upper a arm / balljoint
but I dont see how it will help raise up the car any...
unless it allows the upper a arm to travel further down before it bottoms out on the bump stops...
maby thats it.
1972 Plymouth Valiant / slant 6 auto
 Post subject: lift kit
PostPosted: Fri Jun 11, 2010 4:52 am
It's a complete mystery to me :shock:
max
1966 barracuda 360
PostPosted: Fri Jun 11, 2010 2:15 pm
That's a GM ball joint spacer kit. It doesn't raise the front, it allows the front to have more upward travel under launch.
I haven't seen one of them since I was in high school. :shock:
PostPosted: Fri Jun 11, 2010 4:46 pm
That's correct.
maby thats it.
That is it. It can be the difference between putting a front wheel in the air or keeping it on the ground. The latter is real handy on the strip if/when the rear end steps out.
You can't fix stupid. - Ron White
