| Part # for arp Main studs with Windage Tray provision??? https://slantsix.org/forum/viewtopic.php?t=40619 |
| Author: | Greg Ondayko [ Sun Jun 13, 2010 4:18 pm ] |
| Post subject: | Part # for arp Main studs with Windage Tray provision??? |
Hello, I was wondering if anyone has a part# for the ARP main studs with the provision for mounting the windage tray? Thanks! Greg |
| Author: | Greg Ondayko [ Mon Jun 28, 2010 11:07 am ] |
does anyone know about these or has anyone used them? Do these even exist? Do I have to special order them? Greg |
| Author: | Mister Twister [ Sun Jul 04, 2010 8:06 am ] |
A while back I read you just use the main bolts from the V8 set big block or small block I don't remember tho. |
| Author: | maxracer21 [ Sun Jul 04, 2010 8:13 am ] |
Mine came with the windage tray.........Seymour would know. Someone was building them up there. Might be in a sticky under engines. I do know if you get them too long they will block off the oil passages. The ones I use have a shoulder and a different size thread on the tray side..........hope this helps. Seymour goes by exner geek Regards MaX |
| Author: | Exner Geek [ Sun Jul 04, 2010 8:24 am ] |
I think Maxracer is referring to the bolts that come with Mike Jeffreys windage trays. I am not sure that there are any ARP studs that mount a windage tray, Doug would know if there is. |
| Author: | maxracer21 [ Sun Jul 04, 2010 8:45 am ] |
Thanks............I couldn't remember. You know I never had a bit of trouble with that tray. Still using it w/ a scraper. Just torque them to the right specs, if you can still get them from Mike. appreciated Seymour MaX |
