It is currently Fri Jul 17, 2026 7:23 am
 Post subject: engine info/help
PostPosted: Mon Jun 21, 2010 9:12 pm
I have a 225 out of a 71 valiant I was told, putting it back together and need some help:
#1 were can i get some of those spark plug cup gaskets <orings> the parts store guys dont even know what im talking about.
#2 the fuel pump is mechanical but has a 3/8 in hose coming off it <vaccum?> what does this do and were does it hook to.
#3 can some one post a picture of the power steering pump mount bracet for this motor there is 3 holes in a upside down triangle about 2 inches apart it sits in front of the motor mount on the left <driver> side.
Could use any help you guys have thanks
PostPosted: Fri Jun 25, 2010 10:53 am
I know how you feel, the guys at Autozone looked at my sideways, just give them the part number (Fel-Pro ES 12794), they come in a box of 6 so only order 1.
The pump is mounted to the long side of the bracket, and the short point of the triangle points toward the engine block. If you still don't understand, I can post pictures later.
PostPosted: Sat Jun 26, 2010 7:42 am
I dont have the bracket so i am looking for a picture. I got one off a newer mototr about a mid to late 80s and it doesnt fit on the block so im looking for the other options as i am going thruogh the junkyard
Thanks for the info on the gaskets
