| 9in drum brakes https://slantsix.org/forum/viewtopic.php?t=40768 |
| Author: | 67plymouth [ Thu Jun 24, 2010 9:13 am ] |
| Post subject: | 9in drum brakes |
im lookin for 9in drums for the front but i cant seem to find them anywhere does anyone know where i can find them or know a part # by any chance, I would really appreciated thanks |
| Author: | hellion_locdogg [ Thu Jun 24, 2010 3:23 pm ] |
I have some for sale from a '63 Dart, I just took them off for the HK disc conversion. They can be turned, I also have the spindles. ,Cliff |
| Author: | bcschief [ Thu Jun 24, 2010 7:36 pm ] |
| Post subject: | Brake Drums |
Rock Auto has them $19- $34 Dollars 3 choices Plus you can get a 5% discount see the slanted network forum for the discount code Brian |
| Author: | 67plymouth [ Fri Jun 25, 2010 9:36 am ] |
i only found the rear on rockauto, im looking to buy new ones |
| Author: | emsvitil [ Fri Jun 25, 2010 11:59 am ] |
Look up the 9" drums for younger cars (64,65,66...) until you find them. Don't go past 72,73 or the bolt pattern isn't correct. (check the 'info') Sometimes the lookup isn't complete for various models, so lookup other a-bodies, and different engines to find your parts. If you go far enough, you'll find finned drums. |
| Author: | bcschief [ Fri Jun 25, 2010 12:36 pm ] |
| Post subject: | front drums |
I looked them up for a 63 valiant Brian |
| Author: | 62savoywagon [ Sat Jun 26, 2010 6:37 am ] |
How about wheel cylinders? Rock auto (and nobody else so far) carries them for my '62 Savoy (9" manual drums fore and aft). Anything cross? I'm upgrading eventually......but I need functional brakes kinda now |
| Author: | bcschief [ Sat Jun 26, 2010 7:35 am ] |
I want to point out a 62 savoy has 10 or 11 inch brakes not 9 inch I am not sure about 62 but I know 61 had total contact brakes with 2 wheel cylinders on each wheel Brian |
| Author: | 62savoywagon [ Sat Jun 26, 2010 3:51 pm ] |
Quote: I want to point out a 62 savoy has 10 or 11 inch brakes not 9 inch I am not sure about 62 but I know 61 had total contact brakes with 2 wheel cylinders on each wheel
Brian |
| Author: | 67plymouth [ Tue Jul 06, 2010 9:38 am ] |
for the front does the drum and wheel hub come as one assembly or are they separate |
| Author: | bcschief [ Tue Jul 06, 2010 12:07 pm ] |
separate The original factory front drums were an assy if your drums are factory originals you will have to cut or grind off the swaging around the studs to replace the drum if you try to press out the studs without doing this you will ruin the hubs the stud holes will be oversize. I know this because I had a machine shop do this to my original hubs Brian |
| Author: | 67plymouth [ Tue Jul 06, 2010 10:41 pm ] |
well that makes a lot of sense.... might also be why ive been havin such a hard time finding those front drums |
