Help with stater relay wiring
https://slantsix.org/forum/viewtopic.php?t=40779
Author:  flipfloppop [ Thu Jun 24, 2010 4:55 pm ]
Post subject:  Help with stater relay wiring
I just got this relay http://www.oreillyauto.com/site/c/detai ... yword=s109 and I have no wires or wiring diagram for this. It's for a 1978 Plymouth slant six.
I would like any help in where the wires go from relay to where.
Thank for looking and for any help.
Author:  NspireFX [ Thu Jun 24, 2010 8:06 pm ]
hello bro,
I think this can help you.
the wire from IG SW is a Yellow wire on caliber 14 (under steering column)
the bat wire is a RED wire on caliber 10 (engine compartment)
the SOLENOID wire is a brown wire on caliber 12 (engine compartment)
the Ground Wire is DARK GREEN on caliber 20 in manual transmision under steering column in a clutch pedal sw ), in automatic is a brown wire with yellow trace on caliber 20
Author:  flipfloppop [ Sat Jun 26, 2010 4:56 pm ]
Thanks for the reply it helps alot
Author:  Wesola78 [ Wed Jun 30, 2010 12:17 pm ]
A little late here, but Borg Warner has a website where you can view pics of their components. Back when I relocated the relay, ECU, voltage regulator, and ballast resistor to a panel under my Volare's dash, I used this website to view pics of the starter relay. There are four angles you can view the component from, and the terminals are clearly labeled.
I know you have this issue worked out, I'm just throwing this out there as an FYI.
Author:  flipfloppop [ Wed Jun 30, 2010 2:10 pm ]
Thanks for the help. I have not wired it up but I will soon.
