Getting a wheelie
https://slantsix.org/forum/viewtopic.php?t=40785
Author:  Brussell [ Fri Jun 25, 2010 9:22 am ]
Post subject:  Getting a wheelie
Alrighty, anyone reckon it is possible to get a wheelie in your car from your 225L slant 6.
To get that kind of thing what horsepower or torque is needed or what is the power to weight ratio etc?
Doesn't have to be much just the front two wheels up a little bit.
Was thinking 500hp. with a 2800stall converter and 4.55 diff gears might help?
Or does anyone know of a slant 6 car that's done this
cheers,
Ben
Author:  Shaker223 [ Fri Jun 25, 2010 9:27 am ]
Here is one
http://www.youtube.com/watch?v=VrAqCYhAI5I
Turbo66valiant has pulled the wheel...not sure who else has
Author:  Doc [ Fri Jun 25, 2010 9:55 am ]
I have pulled one wheel up... I'm still working on getting the other in the air.
Author:  madmax/6 [ Fri Jun 25, 2010 8:19 pm ]
I could if I added a 100lbs to the rear but then I probably wouldnt get 1.50s 60 fts,and bee in the 11s in the 1/4.If ya just want a wheelie build a 200hp motor and add 400lbs to the rear behind the axel.My Opinion.Guzzi Mark
Author:  madmax/6 [ Fri Jun 25, 2010 8:29 pm ]
And subframe connectors make two wheels up alot harder than one wheel up.Mark
Author:  turboram [ Sat Jun 26, 2010 10:02 am ]
I get a little light under one not a great picture but it is off
Author:  Exner Geek [ Sat Jun 26, 2010 7:55 pm ]
They had a good article in Car and Driver about two months ago on how to do wheelies. Rear weight bias, high G acceleration, short wheel base, and high CG all tend to transfer more weight to the rear wheels. Your car doesn't need to be terribly fast to pull a wheel off the ground, you do need to apply maximum power right on the starting line-high stall converter, and it helps to have lots of arch in you rear springs on a A body type car. Note that Mark's car has a lower CG and doesn't wheelie but goes faster than the rest of us.
Author:  Rick Covalt [ Sun Jun 27, 2010 5:14 am ]
Post subject:  Altered wheelbase
I saw a 65/66 dart with altered wheelbase and straight axle on E-bay about a month ago. I thought to my self, If I had piles of cash, that this would make one wild slant six powered wheelie machine. 8) 8)
Rick
Author:  Charrlie_S [ Sun Jun 27, 2010 3:29 pm ]
"SIX PACK", 66 Valiant, owned by Barry Harrison, regularly carries the front wheels.
Author:  Dolmetsch [ Sat Jul 31, 2010 1:30 pm ]
http://www.youtube.com/watch?v=-RrGDPXOQtI
Slant six , 8 inch converter hydraulic cam , Eddy four barrrel. 391 gears. Car weighs 1706 as seen here (me driving) AKA The Senior Dragster
Don
Author:  Fopar [ Sat Jul 31, 2010 3:57 pm ]
This is Dave Mueller's
Richard
Author:  maxracer21 [ Sat Jul 31, 2010 4:04 pm ]
I guess that about says it all...... :D
Author:  Mister Twister [ Sun Aug 01, 2010 6:54 am ]
Richard
This one pulls wheelies and is fast :!: Very impressive. Makes me wonder what this car would run with wheelie bars to keep the front end down :shock:
Author:  Team Green [ Sun Aug 01, 2010 2:10 pm ]
Image[/img]
Author:  Dart270 [ Mon Aug 02, 2010 6:54 am ]
Drool...
