| New Process 4530 https://slantsix.org/forum/viewtopic.php?t=40793 |
| Author: | SVLSLIM [ Fri Jun 25, 2010 9:36 pm ] |
| Post subject: | New Process 4530 |
I just went to a salvage yard to pick up a Dodge New Process 435 for a swap I am doing. When I got home and cleaned it up I discovered that the tag actually read Model Number 4530 with a 4.56 gear ratio...actually the this will work better than the 6.69 gear ratio of the 435. Anyway I was wondering if anyone had any information on this transmission? From what I can tell it has all of the same features as the 435 (splines, front and rear retainers, top-cover, bolt pattern). The only differences I see are that it has PTO covers on both sides and the shift lever is slightly different (shorter). |
| Author: | JR [ Sat Jun 26, 2010 5:53 pm ] |
http://www.novak-adapt.com/knowledge/np435.htm You have the same one that I am putting behind a 225 in my 69 D100. |
| Author: | SVLSLIM [ Sat Jun 26, 2010 7:00 pm ] |
So the 4530 is a 435 with two PTO ports? |
