It is currently Sat Nov 21, 2026 5:20 pm
 Post subject: 7 1/4" Ring Gear Bolts
PostPosted: Wed Jun 30, 2010 2:56 pm
I'm in the process of attaching a 3.55 ratio ring gear to a carrier, and the 7/16 bolts I took out of the 3.23 ring gear appear to be too big for the new gear. They look like 3/8 bolts. Anyone run into this situation, and if so is there a good source for the other bolts. They should be left hand thread, right?
PostPosted: Wed Jun 30, 2010 3:28 pm
I have seen 2 different typs of ring gear bolts when working with 8 3/4 gear sets. One type has a slim unthreaded section under the bolt head, the other type has a slight taper or "shoulder" to it.
If the bolts thread into the loose ring gear but they do not clear the thru holes in the carrier flange, I bet this is the issue and you need the other bolt type.
PostPosted: Wed Jun 30, 2010 3:33 pm
This has the shoulder. It looks like I don't have the right bolts.
PostPosted: Wed Jun 30, 2010 3:50 pm
The dealers still have them also summit I'm 90% sure. I looked for some I had but cannot find them ........If I find them before you I'll send them to you pro bono.
best regards MaX
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Wed Jun 30, 2010 4:07 pm
Thanks for the thought, Max.
 Post subject: bolts
PostPosted: Thu Jul 01, 2010 4:55 pm
I found them but they have the dreaded shoulder also ..............sorry.
MaX
1966 barracuda 360
PostPosted: Thu Jul 01, 2010 7:44 pm
I have the straight 7/16 ones. I think the shoulder ones are what I'm looking for. Do they taper down to about 3/8?
Users browsing this forum: No registered users and 18 guests
