| carb?? https://slantsix.org/forum/viewtopic.php?t=40860 |
| Author: | guillermo [ Thu Jul 01, 2010 9:38 pm ] |
| Post subject: | carb?? |
awhille back i posted that i needed help my car was smoking and it smelled like gas . i did a braekdown of my carb{kit} and noticed that power valve lever was missing a washer retainer and a ball bearing they where loose in the carb??? found them inside and noticed that where the lever inserts into the main well body there is missing a cap ??? and spring ??? but there was a ball bearing inside of that hole ??? would any if this issues cause my car to run rich thus smoking? i changed the valve oil seals already . and where can i get that specific parts ????[/img] |
| Author: | gato [ Fri Jul 02, 2010 5:26 am ] |
since u haven't said what carb ur playing with my best suggestion is. . . . . . . since u apparently have dissected ur carb quite extensively, get a rebuild kit for it now and finish the job. follow the instructions in the kit should get u a fresh carb, and get rid of that gas smell. D~~~! |
| Author: | guillermo [ Fri Jul 02, 2010 11:38 am ] |
it is a 1920 holley but what about the missing parts ????? if any ???? |
| Author: | THOR [ Fri Jul 02, 2010 12:29 pm ] |
The 1920 shouldn't have any ball bearings rolling around inside. Can you take some nice detailed shots of your metering block and inside the Carb? ~THOR~ |
| Author: | guillermo [ Fri Jul 02, 2010 9:22 pm ] |
i took some pics but do not know how to paste here can i pm you then send pics . the bearings came out from the power valve lever the second stage hole ? put that bearing back but then i noticed that where the lever enters into a hole in the main well econimizer part there was a bearing which fell out and i think there should be something holding it i ?????? like the power valve second stage ?????????? |
