It is currently Thu May 28, 2026 3:18 am
 Post subject: smoke on highway?
PostPosted: Thu Jul 01, 2010 3:09 am
I have another slant issue . when i'm accelerating onto the high way my vehicle seems to put out some smoke.not running bad or anything just concerned. whats causing this smoke??? only when heavy accelerating with a load,not at idle
thanx for any help ,jim
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Thu Jul 01, 2010 5:04 am
I'm assuming the smoke is blue/blue white.
Sounds like rings.
Have you done a compression check yet?
- Mac
PostPosted: Thu Jul 01, 2010 6:10 am
Car Model: 1968 A108 225/3 on the tree
what color is the smoke?
blue?
white?
black?
PostPosted: Thu Jul 01, 2010 5:40 pm
jim, that van looks like one in webster ma. any help on smoke color?
PostPosted: Fri Jul 02, 2010 4:31 pm
im going to say black smoke it only happens on the highway when accel. no im more around haverhill
thanks jim
PostPosted: Fri Jul 02, 2010 6:09 pm
Rich,choke or carb related,not oil.Mark
PostPosted: Fri Jul 02, 2010 6:26 pm
Yes... black smoke indicates an over-rich condition.
Warm up the engine, then pull the lid off the aircleaner. Is the choke plate fully vertical (open)?
- Mac
PostPosted: Mon Jul 05, 2010 11:13 am
alrite thatl be it i still cant open my choke all the way still have a lost vacuum leak
thanks jim
