Voltage drop while idling - Regulator issue?
https://slantsix.org/forum/viewtopic.php?t=40974
Author:  robjkc [ Sat Jul 10, 2010 5:54 am ]
Post subject:  Voltage drop while idling - Regulator issue?
While idling in neutral (800rpm) w/lights on my battery voltage reads about 14.3 volts, but when I put it in drive (~650rpm) my battery voltage drops to around 13 volts. When I put it back in neutral the voltage slowly climbs back to 14.3.
If I set my idle any lower the car wants to die while in drive.
Could this be a voltage regulator issue? Both my battery and alternator have checked out okay.
Thanks for the help!
Author:  emsvitil [ Sat Jul 10, 2010 1:59 pm ]
What year is your car?
This is normal with older low-amp alternators.
Author:  robjkc [ Sat Jul 10, 2010 3:36 pm ]
Sorry, its a 64 Dart. That's good to hear that it's normal. Thanks for the information!
Author:  maxracer21 [ Sat Jul 10, 2010 3:51 pm ]
Post subject:  Alternator
go to the electrical portion of this site and it'll show you how to update your alt. makes all the difference......welcome to the site BTW
MaX
Author:  robjkc [ Sat Jul 10, 2010 4:18 pm ]
Post subject:  Re: Alternator
go to the electrical portion of this site and it'll show you how to update your alt. makes all the difference......welcome to the site BTW MaX
Thanks MaX! I was just looking around and found this link about upgrading the alternator:
http://www.imperialclub.com/Repair/Elec ... arging.htm
Is this what you are referring to?
Also, thanks for the welcome!
Author:  maxracer21 [ Sat Jul 10, 2010 6:51 pm ]
Post subject:  Alternator upgrade
Yep .........that's it .........way too simple just find you a two field alternator and ground one of the field wires to the alt. Then proceed as normal........you'll be happy ..car will be happy
take care
max
Author:  robjkc [ Sat Jul 10, 2010 7:59 pm ]
Post subject:  Re: Alternator upgrade
take care
max
You mentioned grounding one of the field wires to the alternator. In the link they suggest connecting the second field wire to the new VR. Does that sound right to you? Anyway, I'll do some more reading as I've got a lot to learn. Thanks for the help!
Author:  maxracer21 [ Sun Jul 11, 2010 5:53 am ]
You are right .............that thread is if you want to upgrade your alternator regulator.
If you don't want to go with the transistorised voltage reg., just ground one field wire to the alt case and leave everything as is. Sorry about the mis-understanding.
MaX
Lots more info in electrical the hEI set up is great!
Author:  robjkc [ Sun Jul 11, 2010 10:21 am ]
Yeah, the hEI update is next on my list. I just need to figure out how to setup the relay (been studying up on my electrical). I also want to keep a clean look without a lot of wires and possibly go back to the points system as a backup.
As far as the alternator upgrade (newer alternator with second field wire grounded), is the primary benefit just having the bigger alternator (more output) or is there something else causing the improvement?
Author:  maxracer21 [ Sun Jul 11, 2010 11:23 am ]
You'll get 60 amps instead of 35 to 40 amps. just by changing the alt and grounding the field wire.
MaX
