It is currently Thu Jun 04, 2026 11:53 pm
PostPosted: Thu Aug 05, 2010 12:44 am
My engine:
I know this engine is in need of TLC... and the carb is SOLEX(!) non-ori... and the brake master cyl is not original either...Oh Ignore the Yellow Motor Oil container (the fuel tank is full of sediments and rust)... but...
Is this a 170 or 225?
Cheers
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Thu Aug 05, 2010 1:22 am
Hello,
Impossible to tell from those pictures
The search function is your friend, BUT, if you are unwilling to use it,look about 12 threads down this "Engine"page. You will no doubt find what you are looking for.
This discussion has been discussed MANY times here.
regards,Rod
:D
PostPosted: Thu Aug 05, 2010 1:26 am
Hello,
regards,Rod
:D
Ok will do... but... i've been told there are visual cues... such as shorter water pump hose(?)... But yeah will search for other threads...
Cheers
Syed
PostPosted: Thu Aug 05, 2010 1:43 am
try here:
http://www.slantsix.org/forum/viewtopic ... 170#280207
regards,Rod
PostPosted: Thu Aug 05, 2010 7:53 pm
Its OFFICIAL... she has the 170 :)
Engine number (under 1st spark plug) :
170 11 24
Casting number on the block (under the manifold)
2463230-1
PS: Anything more I can find out from these two set of numbers?
Cheers
Syed
PostPosted: Fri Aug 06, 2010 5:04 am
Yup, a 1965 170 ci. block. I recall you stating that your car was an early build 1966, so this is correct.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 8 guests
